How is the throttle cable and tube routed from trigger to carbueretor?
Hi David-
I found this youtube video regarding 122c Husqvarna throttle cable placement.
https://www.youtube.com/watch?v=eUwaRtzhaQ0
I found this link regarding your Husqvarna 122C owners manual (OM) and Parts List (IPL).
https://www.husqvarna.com/ca-en/support/manuals-downloads/
I also found this link regarding Workshop manual for your Husqvarna 122C trimmer.
https://www.google.com/search?ei=BLHeXZv8I4-WsQWBhYjoBA&q=How+is+the+throttle+cable+and+tube+routed+from+trigger+to+carburetor+122c+Husqvarna%3F&oq=How+is+the+throttle+cable+and+tube+routed+from+trigger+to+carburetor+122c+Husqvarna%3F&gs_l=psy-ab.3...9359.61712..73674...0.2..0.130.2047.3j16......0....1..gws-wiz.......0i71j33i10.d34Ms2LVkiY&ved=0ahUKEwibjtGE9IrmAhUPS6wKHYECAk0Q4dUDCAs&uact=5
Click on (pdf)Workshop Manual 265/252/250... link.
Hope this helps.
SOURCE: throttle cable
This advice is not model specific, but normally you would remove the air filter and access it that way.
Usually the actual fitting of the cable to the carburettor is pretty fiddly; sometimes it is easier to remove the carb, to do it.
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
SOURCE: The spring placement for the trigger replacement
Look at the old trigger and see where the spring has been rubbing. Place the spring around the trigger post and slide it into the trigger housing. With help of a small screw driver or scribe to flip the trailing end of the spring over the stop post in the housing. Hope this helps
SOURCE: installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
SOURCE: throttle trigger cable
it can be repaired, but you must order the new part from the manufacturer. . .i'd get a new one
