Stanley model 550Z brand new.
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
SOURCE: Can you help with loading
Look at rear handle bottom, Push in then pull out,load. Please rate. Thanks
SOURCE: How do you load staples in the Stanley TRA 700?
Howdy, pull out the plunger to its farthest and turn stapler upside down (staple output pointing up) and lay staples in track (in front of plunger) then push plunger back in.
Super handy when you get used to it:)
Regards, farmerbear
Testimonial: "This is a great place to find easy answers to problems we all run into. Don't hesitate to ask. Readers will help. Thanks!"
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Hi Bruce Morrison, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
