Like if the circuit board went out so you want to know what wires could be used to put voltage to so that the unit runs at 2 settings "on and off" and if so would u just run ac directly or dc?
SOURCE: roof duotherm ac not working
do not do you will burn up compressor and cause fire making lots of heat and not cool
SOURCE: wiring
Not sure about the actual voltage, but the primary power board shows 94 V @ 2A. As this appears to be a variable speed drive, the voltage amplitude should vary depending on the speed potentiometer setting. The most likely culprit is the speed potentiometer. Poor design causes vibrations on the printed circuit board. This induces metal fatigue in the potentiometer terminations at the board. Eventually one or more terminals snap off. You could try removing the pot and connecting the wiper termination connection directly to the relative end for full speed? This is assuming you want it to run at full speed? Failing that you could try variable resistance settings and then replace the pot with a fixed resistance for the required final speed?
