Televison & Video Logo
Hugo Vera Posted on May 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Necesito los cuatro digitos para un tv haier - Haier Televison & Video
Tom Chichester
Level 3:
Top Expert:
  • Haier Master 62,329 Answers
  • Posted on Nov 08, 2020
Tom Chichester
Haier Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
670746
Points
975369
The code for your Haier TV would be found in a compatible remote control.
5 Related Answers
Anonymous
  • Posted on Sep 09, 2009
SOURCE: necesito el codigo del control ge rc24912
i need the codes four tv philips
Anonymous
  • 325 Answers
  • Posted on Oct 11, 2009
SOURCE: necesito los codigos para programar el control
Sharp 011,020,025,027,037,052,053,059
cheers
Little Dish Fitter
gopakumarg43
  • 76851 Answers
  • Posted on Feb 10, 2011
SOURCE: necesitos los codigos para activar un tv PHILIPS
Hello
Three digit remote codes for Philips with Chunchp remote are:-
013/023/024/039/040/043/141/241/242
Try out with these codes. One amoung them will awaken your TV. OK.
gopakumarg43
  • 76851 Answers
  • Posted on Mar 30, 2012
SOURCE: necesito codigos de 4 digitos para tv. magnavox
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method.
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
gopakumarg43
  • 76851 Answers
  • Posted on May 07, 2012
SOURCE: codigos para lcd haier
0081 0216 0217 0157
Tengo un tv westinghouse ew24t7ew necesito un codigo para canales de aire
Hola, tengo una pantalla westingjose modelo w42f17- sm quiero restaurarla pero me pide un codigo de 4 digitos, ayuda por favor
7helpful
13answers
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
58helpful
9answers
4helpful
3answers
Necesito los codigos para una television philips de un mando thomson roc4306
hola necesito los codigos para tv toshiba del mando a distancia Roc 4306
2helpful
4answers
Nesecito los codigos para programar un control universal janesong js-1000c en un dvd daewo. saludos.
086-087-187-188-189-190-191-192-193-194-267-279-325
fente : manual del control
recuerda
encender DVD y ponerlo en pausa
presionar SET del control durante 5 segundos
escribir el código de 3 digitos
presionar PLAY > del control, si funciona presionar otros botones para probar y presionar SET otra vez para grabar el código en el control
prueba los codigo de la lista
16helpful
Codigos para televisor LG Haier y Coby
hola mi nombre es henrys hernandez pero necesito los codigos para un tv plasma coby sin mas gracias mi correo es [email protected]
58helpful
8answers
CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
