SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
SOURCE: Fix a lens on my dmc-fx9
It sounds like you have a gear problem in your lens. If you need some good used parts for your FX9 you may want to contact a guy in South Carolina who has lots of parts for all the Panasonic Cameras at reasonable prices. I think his email is [email protected]
SOURCE: how do I reset my Panasonic DMC-FX35 to facoty
you'r menu should have a reset setting, there are 2 menu's 1 when you'r ready to take a picture & 1 when you'r viewing you taken pictures
SOURCE: Panasonic Lumix DMC -FH20 lens
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
SOURCE: how do i factory reset my panasonix lumix dmc-fz45
Remove the batteries for 60 seconds, at the same time press power and hold for the juration of the time, this will remove residual voltage and reset the processor ic, "long shot" if no change the zoom part of the lens is malfunctioning, the zoom motor or gears are jammed.
