SOURCE: Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
SOURCE: I just purchased a used Ariens sport zoom 1440.
Change the oil and air filter. Look for grease fittings on all moving parts and give them a shot.
SOURCE: The engine will not stay running (Ariens 34' Zoom)
a lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
SOURCE: I have an ariens zoom 1540 hydrostatic mower. One
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
