SOURCE: stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
SOURCE: hit the throttle it quits running . it starts
Conected to the rubber induction boot is the impulse hose, it is a short curled pipe, make sure this has not split and is conected to the two nipples on the carb flange.
SOURCE: stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate
2StrokeJim
SOURCE: put a new carb on my stihl 400 backpack also a new
Lucy, the problem is that you have a blocked tank vent/ gas cap. Try just loosening the gas cap,just a crack not even one turn. You are bypassing the tank vent. Now start it and see if it runs longer with out boggind down.If this fixes it, you will need a new gas cap.
Let me know
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
