Most likely the charger is separate from the drill, but I didn't see a manual online. May want to check at local hardware type store.
https://www.homedepot.com/p/RYOBI-12-Volt-Lithium-Ion-Cordless-3-8-in-Drill-Driver-Kit-with-12-Volt-Battery-and-Charger-HJP004L/300981190?cm_mmc=Shopping%7CG%7CBase%7CD25T%7C25-9_PORTABLE+POWER%7CNA%7CLIA%7c71700000044155732%7c58700004615424082%7c92700043235553558&gclid=CjwKCAjwiN_mBRBBEiwA9N-e_qVz_xDgJC6XyW8Vk3lpVppcnSnIzfMb8W1hfIsxGm_YB1LkQIWPzBoCnHQQAvD_BwE&gclsrc=aw.ds
SOURCE: model cd55 Ryobi cordless drill driver
Your drill probably has a bad or stripped drive gear. Does the drill operate in forward w/a battery that is not fully charged but yet good.?
SOURCE: delta cordless drill
Hi, I have the same problem. Am looking to order a new cord. The model # for the battery charger cord is CL120C.
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
SOURCE: battery won't charge on my ryobi 14.4v cordless
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
