SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
SOURCE: machine will not grind beans.
That error message will also appear if the coffee grind is too fine.
SOURCE: Saeco magic comfort coffee machine grinder
Empty beans out. Take the two screws out.
Put bean grade to 1. Run the machine as if making coffee. Use a vacuum and clean the bean grinding machine area. Run the machine again.
Place bean container back and put screws back in. Fill bean container.
This worked for me
SOURCE: Water (coffee) does not make it out through the
Propably the vibrating water pump is the problem.
It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water. Then try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Testimonial: "Brilliant, I cleaned the shower head as you instructed and it's working perfect, thanks for the tips. Louise"
