Computers & Internet Logo
Carlos Chang Posted on May 09, 2019
Pinnacle Studio 9 version 9.4.3 es compatible con window 10?
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jun 10, 2008
SOURCE: pinnacle studio v 9 not compatible with windows vista?
Only version 10 (and higher) is supported for Windows Vista.
They have pretty good deal going on for upgrades. I think you can upgrade to version 11 for $58.00
Anonymous
  • 50 Answers
  • Posted on Nov 17, 2009
SOURCE: Is Pinnacle studio 9 compatible with Vista home
It sure is. I'm running it on this machine with no problem.
Anonymous
  • 217 Answers
  • Posted on Aug 17, 2010
SOURCE: I can't find Serial Nr.
Welcome to fixya,
You can get the serial number by contacting Pinnacle Support center
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Jan 08, 2011
SOURCE: I HAVE NEW COMPUTER,WINDOWS
I believe it is compatible ...what it asks is the driver for the tv tuner if this is what you use...cause the driver can not be compatible ...even if the software might be ...
so what you need is to insert the disk that came with the tuner and in there run the drivers for vista if you do not have the drivers for windows 7 on it ..or...see the model and look on the manufacturer-s site..and download the latest drivers for windows 7 ..after that will work ..
to get to the manufacturer's site..just type its name ..and the word support into an search engine ..and if a site named....support appears..get in there ..make sure it is the manufacturer's support site ...select the model into the driver and downloads..and the operation system ..and get the driver for it ..
Kushal Madane
  • 73 Answers
  • Posted on Jul 13, 2011
SOURCE: I have upgraded my system
Try running the program in compatibility mode.
Windows 7 is having this feature.
Right click on the program you want to run.
Click on Troubleshoot compatibility
then select try recommended settings.
Then run the program
2answers
Pinnacle Studio 11
From the looks of it there's no Vista support yet. Pinnacle Systems needs to come out with somekind of patch soon. I've been looking for an hour as well. Couldn't find anything but people discussing the fact that they need the patch badly. On the Pinnacle site there's a link to software for Dazzle Video Creator 9 but it leads to an error page.
I guess you'll have to watch carefully when an update arrives.
Or try to find something of an automatic update feature in the software, maybe it'll find something.
You can try simpler programs such as Windows Movie Maker but I don't think it suits your needs when you want to edit stuff.
Another solution might be Sony Vegas.
For more information on the Sony Vegas product family, click link below:
[Sony Vegas Product Family at SonyCreativeSoftware.com]
I hope this will help you out. It's really frustrating that you buy software and then you can't use it on Vista.
Greetings,
DarkNeogen.
2helpful
Have Pinnacle Studio 9 AV/DV that I purchased around 2004 and currenly have a new computer that I re-loaded the software to. I have no PASSPORT numbers in 'HELP', just an all alpha serial number. My...
You can contact Pinnacle and ask them for a replacement key, but I would suspect they will want you to buy an upgrade to your software. If your new PC is windows 7, your 2004 software will probably not work with it even if you have a code for it.
The good news is that the newer version probably has more features etc. and an upgrade option (if there is one) can save you $ over buying a full version.
I know for my own example that Roxio (another CD/DVD program) is only compatible with windows 7 on their 2010, and now their 2011 versions. Anything else will not work.
When I was instoling pinnacle studio ustimate version 14, which I received when I bought camcord, it ask me that I don't have windo3.4. what can I do?
The system requirements for Pinnacle Studio Ultimate 14
1) Windows® 7, Windows Vista® (SP2), Windows XP (SP3) operating system.
2) Intel® Pentium® or AMD Athlon™ 1.8 GHz (2.4 GHz or higher recommended)
Intel Core™2 Duo 2.4 GHz required for AVCHD*, Intel Core™2 Quad 2.66 GHz or Intel Core i7 required for AVCHD* 1920.
3) 1 GB system memory recommended, 2 GB required for AVCHD*
4) A DirectX® 9 or 10 compatible graphics card with 64 MB (128 MB or higher recommended)
128 MB required for Red Giant Magic Bullet Looks Plug-in: Pixelshader 2 required, Intel GMA integrated graphics not supported. 256 MB required for HD and AVCHD*
5) DirectX 9 or higher compatible sound card.
6) 3,6 GB of free hard disk space.
7) DVD-ROM drive to install software.
Check to see if your system forfills the minimum system requirements.
1helpful
The Pinnacle Studio which worked on Windows XP does not work on Window 7. What upgrade software should i get?
I think the best option for you is to Upgrade to Pinnacle Studio 14 which is $0, or Pinnacle Studio 14 Ultimate, which costs $70. An upgrade is cheaper than buying the entire version which will cost you about $130. The upgrade will work with Windows 7, Windows Vista (SP2), Windows XP (SP3).
On the other hand, if a program cannot be run under Windows 7 because of compatibility issues, you can right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. This will make it run as if it was running in Windows XP. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Is Pinnacle studio 9 compatible with Vista home basic
My activation key file missing
Mensaje de error 'La clave de activacion no es valida' al introducir una clave manualmente en Studio Claves de activacion se utilizan para desbloquear ciertas caracteristicas de su programa (efectos especiales, plugins etc) y se generan teniendo en cuenta el pasaporte de su ordenador.
Si ha formateado el disco duro o esta instalado Studio en un sistema nuevo, tendra un nuevo pasaporte en este ordenador y las claves que tenia antes no funcionaran mas.
Tendra que regenerar e introducir de nuevo las claves de activacion para cualquier contenido adicional (i.e. HollywoodFX pack, Video Effect, Audio Effect o 3rd party plug-in) que ha comprado y desbloqueado antes.
Tambien, si va a instalar una version de Studio mas reciente en otro ordenador (o ha formateado el ordenador), tendra que regenerar las claves para poder utilizarlas con la nueva version de Studio.
Nota: la regeneracion de claves es gratuida.
Las claves de activacion se pueden regenerar realizando el procedimiento descrito a continuacion:
Tiene Studio 12 & 11 (Standard - Plus - Ultimate) y su ordenador tiene conexion al Internet
  • En Studio, click en Ayuda y seleccione Regenerar claves de activacion.
  • Introduzca su direccion de email. Saldra automaticamente el nuevo pasaporte. Tiene que acceptar.
  • Las nuevas claves seran regeneradas e introducidas automaticamente en el programa. Tambien puede imprimir las claves. En su correo electronico recibira un email con las claves.
Tiene Studio 10 (QuickStart - Standard - Plus) o Studio 9 (Standard - Plus) o su ordenador no tiene conexion al Internet.
1. En Studio click en Ayuda -> Mi Pasaporte. Apunta el numero de pasaporte, que es una sequencia de 5 grupos, cada uno con 5 numeros. Como es una sequencia de 25 digitos, muchos clientes prefieren copiar y pegar el numero en el campo del paso 3. Mantenga esta ventana abierta.
2. Vaya a la pagina de desbloqueo para regenerar las claves de activacion.
3. Rellene la pantalla
  • Correo electronico:
  • Pasaporte, manualmente o copiando y pegando el numero en el campo
  • Idioma preferida
Nota: Sus clvaes de activacion seran enviadas al correo electronico. Es muy importante utilizar el mismo email que ha utilizado para registrar su producto. Si ha cambiado el email, tendra que actualizar su perfil y despues regenerar las claves.
Al haber recibido el email con las nuevas claves de activacion, las puede introducir en Studio:
  • En Studio click en Ayuda -> Introducir Claves de Activacion.
  • Escriba las claves en el campo apropriado y despues pulse en Aceptar.
Puede ver las claves de activacion en Ayuda -> Ver Claves de Activacion
Si no puede regenerar las claves de activacion o recibe algun mensage de error, le pedimos por favor que se comunique con el soporte por email con la siguiente informacion:
  • lista de claves que se tienen que regenerar
  • direccion de email utilizada para registrar el programa (si ha cambiado su email, tiene que decir esto tambien y enviar el nuevo email para que el agente actualice su perfil)
  • el nuevo pasaporte
  • numeros de pedido que ha recibido al adquirir las claves
Pinnacle studio v 9 not compatible with windows vista?
Top Pinnacle Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
