SOURCE: I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
SOURCE: The drying vent on the front of our miele
if you remove the door panel you will see a small hose from the fan to the combi dispener. Remove this and blow through it. Also connect it to the combi dispener and blow and then to the fan end and blow. Food and muck block the pipe and the excess water cannot escape back into the unit so instead it pours out the vent. you will find the fan is then quieter.
SOURCE: Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
SOURCE: Miele Dishwasher is not cleaning dishes
check the filters. also check drain. Sounds like it's not fully draining and/or there is not enough water (ie. when filter are clogged)curculating to wash the dishes properly
SOURCE: miele dishwasher finishes the cycle with water in
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
Dishwasher Problems - Water will not drain out
heatman101
