SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions, try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to hp at 1888 473 2963
SOURCE: cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Testimonial: "This site is excellent. Thanks for your help."
SOURCE: I am using an hp officejet 6500 and I keep getting
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool
SOURCE: my printer keeps on saying cartridge error
hi my friend
you need to replace one or both of your cartridges with new ones
if you have the old you can check , what cartridge couse the error and you can refill the old one like this
if i helped you pls vote
SOURCE: Paper Jam HP OfficeJet 8500
Constant jam indication. This gear is more than likely the cause after exhausting all other avenues. Also nearly impossible to get to let alone replace even if HP offered the part. There is a black cover over the clutch assy that can be removed to reveal the gear. In most cases the gear is either sitting in the bottom of the machine or split down one side. This is the second machine that I have diagnosed with this problem in a very short time. If you have this broken gear, consider it toast. Matt / E-tech Copier and printer repair.
