Hello Carey, you can find the alarm configuration form, which appears in the Quick Guide of your Timex clock radio T235Y.
I sent you the link, so you can download it
I hope you manage to schedule your Timex
Greetings Franco Dosil
Hola Carey, puedes encontrar la forma de configuracion de alarma, que aparece en la Guia Rapida de tu Timex clock radio T235Y.
Te envio el link, para que puedas descargarlo
Espero logres programar tu Timex
Saludos Franco Dosil
https://data2.manualslib.com/pdf4/80/7988/798701-timex/t235.pdf?4a0b39d025e7d16ec28f8e4574be1d11&take=binary
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
