SOURCE: reset fuser
Unforunately once a fuser goes, you are out of luck. I don't know of any printer that will continue to work once the fuser has gone bad. It's best to keep an extra fuser handy for business-critical printers.
SOURCE: How do you replace the fuse in the Bizhub C450
First you have to have the fuse. It is a very specialized fuse. It cost $5 at precisionroller.com part number is M9970. See the bottom of this post for a picture of the fuse.
Once you get the fuse then you are going to have to remove the fuser. After removal look for the large connector on the unit. It will be surrounded by a plastic cover which comes off with 2 screws. After cover removal just look at the wires. The old fuse will be help in with the wires with 2 plastic wire ties. Cut them off being VERY carefull not to cut any of the wires. Just resolder the new fuse in place of the old one being sure to tape any bare wire. Re-install everything and the machine will do the rest.
Now this is a simplified explanation. If you have the required mechanical skills what I have told you will allow to do the job. If all of this sounds like I am talking in a foreign language then my suggestion is to have a service guy do the reset for you.
Good Luck and Thank You for using Fixya.
Testimonial: "Quick response. Good info"
SOURCE: I have bizhub c250 and
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Testimonial: "Thanks"
SOURCE: can you reset fuser counter without replacing the
You can. You have to remove the fuser, and replace the counter reset fuse that is soldered into the wiring harness, then re-install the fuser. 10 minute job but not a one I would recommend unless you know the machine pretty well. Depending on your location and service options I would try to find a local independant repair person who can do this for you. I reset 20 to 30 of these fusers per year. Note you can also reset your transfer belt unit as well as your Imaging Units as well.
WheatlandServices
Testimonial: "thank you very much. I can tell, you're really an expert. your response was very helpful, i will contact a good technician right away to change fuse."
SOURCE: how to reset fuser unit forkonica minolta bizhub
In tech mode :
System 1
Initialization
Counter Data fixing Unit
Start button
Shut off the copier ans switch on
