Netflix viewing not available to search and add and watch
Https://androidpcreview.com/easy-android-tv-box-setup/ see if this helps you just copy and paste in your browser.
SOURCE: Puma Watch PU900111004 (orange heart rate watch)
I want to change the time but was not as
I could help?
SOURCE: I get the following message when I try to open the
Follow these steps one by one and check:
1. Disconnect the Router from the Computer and connect it again.
2. Reboot/Restart the Router by turning it OFF and ON after one minute.
3. Check the connecting wire is properly connected.
4. Open the command prompt and ping 192.168.1.1
5. Try changing the connecting Wire.
6. Try to login using different Computer.
7. Reset the Router by pressing the reset button and configure it again.
NOTE: Always try to login to a Router using a Wired connection not using a Wireless connection.
Good Luck!!!!!!!!!!!!!!!
SOURCE: How do I watch a tv series on Netflix that I have already viewed?
Click the "Browse" link, and you will see a Recently Watched section. Click on the words "Recently Watched," and it will take you to a list of your activity.
You can also click on the little down arrow next to your profile icon in the upper right-hand corner. From the menu that drops down, click on "Your Account." In the "Your Profile" activity, click on "Viewing activity."
Either way, you'll see a chronological list of everything you've viewed, starting with the most recent.
