SOURCE: I have a cello 19" lcd tv that won't switch on and
Hi Dolly,
My cello is doing this as well.....have you had any luck?
LJ
SOURCE: Luxor 42 inch lcd tv stanby light flashing and tv
Good day!!!!
Kindly,count the blinks of your TV because some TV have error code by means of how many blinks..
thank you
you need to take it to a TV shop
or... what i do is look on EBAY for a replacement PSU panel
for the exact model number
check the PSU pcb inside the set for its part number to help match it
you give too little info for me to help further
you need make model and exact problem
its a psu issue for sure.....
some electrolytic capacitors are dried up as its aged
this is the usual cause
SOURCE: When I switch my luxor TV off it keeps flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
