christian castellanos Posted on May 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I open the headphone Jbl duet bt? - JBL Audio Players & Recorders
Grubhead
Level 3:
  • JBL Master 5,755 Answers
  • Posted on May 09, 2019
 Grubhead
JBL Master
Level 3:
Answers
5755
Questions
Helped
1661847
Points
11417
You might need to go via the foam side. Often you have to remove the foam and that shows the access screws. You can glue the foam back with Bostick after you have done. Or you can look around for new foam pads.
2answers
Can u connect JBL HEADPHONES TO TH-P42X20Z TV
yes but setting it up using wireless headphones would be easier.
3.5mm to RCA Stereo Audio Cable Adapter
Amazon Basics 1-Male to 2-Female RCA Y-Adapter Splitter Cable - 12-Inches
copy and paste
https://www.manualslib.com/manual/700621/Panasonic-Viera-Th-P42u20z.html?page=11#manual
My JBL E50BT Headphones bluetooth wont turn on. when i press the bluetooth button nothing happens and no light shows (normally light shows and you hear a beep) please help.
I would start by charging the headphones overnight. Try to use them in the morning. If this does not resolve the problem, either the charger or the headphones are bad. You can contact JBL and see if your set is still under warranty. You should still be able to use them with a wire if everything else fails. It might not look as cool, but at least you can still listen to them. My JBL Account Login
How do you charge them
The JBL logo on the right earbud has a little hinge you can open and plug in any micro usb charger.
1helpful
Jbl reflect bt how to use
Enable th e BT on your device.
Search for the BT JBL and establish the connection when it appears.
Open the player on your device and stream the audio file.
Enjoy.
5helpful
2answers
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
1helpful
Jbl 610 driver
Windows Vista should see the bluetooth headphones without any extra drivers. If you open your bluetooth options, and you can see the headphones, and it asks for a password, try 0000 or 1111.
Also - check your computer to ensure that it does have bluetooth capability. If the computer doesn't have bluetooth built in, you'll need to use the USB communicator that should have come with the headphones. If you don't have the USB stick that came with the headphones, your best bet is to contact JBL and see if they will send you a new one.
Another thing you can try, just to verify the headphones are good - is to try to sync them with an ipod or iphone and see if you can listen to music through them.
3answers
Do headphones NOT work in these speakers or do they have to be jbl brand headphones?
Not really, see the headphone connector if it fits the unit. If it fits but doesnt work then the headphones may have a problem. HOpe this helps and have a good one!
5helpful
2answers
JBL 410 headphones broken
The same happened to me. JBL says that repair services are not available for this product according to their website. Their suggestion is to buy a new pair!!!!!. What a shame. JBL products are quite good but the post service is ****.
Speakers not working
If you have another computer or a friend, test them on his/her computer. Try this, as its fixed such a problem for me in the past. Start>All Programs>Accessories>Entertainment>Volume Control Then check the ticked/unticked boxes
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
