Question about Franklin Industries Franklin Chef Ice Cube Machine FIM400
Manitowoc Icemaker Compressor Will Not Start
I am working on a Manitowoc QY1304A Ice Machine. It is 220v and the problem is the compressor will not start. I have checked the contactor and I have 220v on both sides. I did a resistance test on the PTCR and it is withhin tolerances. I checked at the compressor and I have 220v. The only thing I can think to do is replace the capacitor but I see no physical damage to it. It is not swollen or leaking. I tried testing it with a multi meter and the oms go up till they reach the top scale of the meter. If I short it it will charge again. I also checked the compressor for ground and found none. Check the compressor between the windings and they seem to add up fine. Please help, Joe
    President:
  • 704 Answers
I'd think that the start capacitor is faulty and could be the problem.
Here's a parts list for the model you're working on that also contains several line drawings
http://www.manitowocice.com/documents/miien/service/partsmanuals/icemachines/qseries/qmodels/Q1300.pdf
Here's the online service manuals for the ice machines.
http://www.manitowocice.com/service/servicemanuals.asp
Just click on the link to expand the search and go down until you get to the "Q" series and select the "troubleshooting guide" and any other parts of the tech manual you need, it's all there including the technician's guide too.
Hope you found this info very helpful and best regards!
Posted on Aug 07, 2009
Anonymous
SOURCE:
Compressor wont turn on capacitor was replaced?
Check HP switch (red button on top pushes back down). Check power from relay to compressor. Clean condenser thoroughly.
Jan 16, 2014 | Manitowoc QY0275W Ice Machine Cuber...
My manitowoc series 420 has a code telling me the compressor discharge temperature
Which code is that? I don't see that in the service manual. There is an E09 that indicates that during the first six minutes of freeze the discharge temperature was below the average of the last 6 cycles. I have searched from E01 to E31 and don't see the code you indicate but I would say you either have a low refrigerant charge, a flooding TXV that is allowing too much refrigerant flow into the evaporator and not allowing enough flow to be diverted into harvest, or a weak compressor. Reset the unit and check the temperatures on the display while its running and time a freeze cycle. Should take about 15 minutes to make ice.
Jun 28, 2013 | Manitowoc ID-0452A 420 Lb Full Size Cube...
Won't make ice in cold weather
Check the thermostat of your Ice maker whether it is in working condition or not. For More information please visit GE Ice Machine Cleaner.
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
I have a Manitowoc QD0212A 120v. It makes ice, but after the bin gets full, it appears that the compressor does not run to cool the ice box. Is there some type of relay or solenoid that could be bad?
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Jun 29, 2011 | Manitowoc - QD-0212A/115-1
Manitowoc QY1304A Ice Machine Compressor will not start
Does the compressor make any noise at all?
You can ohm out the compressor windings. I dont know off the top of my head which compressor manufacturer they are using but if it is Copeland you can get an electrical handbook and it will have ohm values for the compressor. If not assume the rule of thumb Common to Run is X, Common to Start is Y, Start to Run is X+Y, and Y should be 3 to 5 times whatever X is. On Rx10,000 scale check each terminal to ground should be open.
Aug 06, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Franklin Industries Franklin Chef Ice Cube Machine FIM400 Logo
652 people viewed this question
Top Franklin Industries Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
