RCA F27450 27" TV Logo
Posted on Nov 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba television When i switch T.V. on it will only stay on for a few minutes and then shut off to stand-by mode, can any one help me as it is only 3 years old, thanks in advance.
  • OLD DUB Nov 27, 2007
    Hi Bill, it is a toshiba television, model number is 36ZD26P.
    Picture and audio are okay when switched on, and yes the lapse in time does get longer, sorry for delay.
    THANKS.
    Hi Bill, model number is 36zd26p and its a toshiba, picture and audio okay, when turning back on the lapse in time does get longer, thanks bill, sorry for delay.
Anonymous
Level 3:
  • Master 934 Answers
  • Posted on Nov 27, 2007
Anonymous
Master
Level 3:
Answers
934
Questions
Helped
504502
Points
2229
Is it a Toshiba or RCA? What's the model number?? When it "stays on..." do you get a picture and audio okay??? If you continue turning it back on does the lapse in time continue to get longer????
Bill
Hello my television is a sony KV32HX15U , when I switch it on the picture takes about 10 seconds to display the television then stays on for about 20 minutes then switches off into stand by mode and...
Hi Gareth,
This model no. has a built-in "self diagnostic software" that can be access to narrow down where the fault came from.
How to enter to self diagnostic screen display.
1. Turn on the main power switch of the TV and enter into standby mode.
2. Press the following sequence of buttons on the remote control.
Self diagnostic error menu will be display. It has an error code no. with the corresponding numerical digit "0" means no fault detected or "1" fault has been detected. See sample picture below.
Please let me know the result to assist you further.
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
I have an LG 47LB5D LCD Tv that shuts off after approximately 30 minutes running time. It will cycle back on after a few minutes, so I assumed it was the power control board; replaced it but Tv still shuts...
It sounds as if the resistors on the board of the television are shot not much that can be done but replace all of the boards in the television you should try and aim fans into the vents on the television and see if its stays on for longer
2helpful
2answers
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
2answers
No picture, starts normally then shuts off. blue light stays on. replaced lamp, and still the same problem. toshiba 62hm196
If a tv turns off after being turned on It is enambling the safe mode to prevent greater damage. It has probably got a bas chip or sync switch on the power board.
1helpful
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
20helpful
6answers
Onida stand by problem
sir my onida tv 21'' ineed un lock
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
TOSHIBA TELEVISION MODEL NUMBER 36ZD26P
You most likely have some broken solder connections either in the low voltage area or in the horizontal section of the tv, board has to be removed and re-soldered, hope this helps
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
