The easiest way for you to get it back to English would be to restore it back to factory settings. First, you should back up all of the stuff that you have on the ipod as restoring it will erase everything off of it. Then go into itunes and go to the ipods main page where memory information is. There should be right under the picture of the ipod 2 boxes, one saying check for updates and the other saying restore to factory settings. Click that one and after it finishes, it should be back in English.
SOURCE: apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides
back and forth. It needs to be switched to the left. Once it is to the
left, here's how you reset:
You can reset your ipod by holding down the menu and select (round
button in the center) buttons down for at least 10 seconds. You'll see
an apple logo flash, that's when you stop pressing the buttons. It will
shut off, then back on.
SOURCE: how do i reset my nano ipod password ive tried the apple instructions?
---If you do this you won't lose music"---
Well I went to my computer clicked my ipod and when the folders came up you go up top to "tools and folder options" and go to the tab that says "view" and click the one that says "show hidden folders." Then click "ipod control" then "Device" and delete the file that says "_lock" or something on that line. If you any questions email me at [email protected]
SOURCE: apple ipod hang
Try resetting it by toggling the hold switch and putting it back in the off position. Then press and hold the center button and the menu button for about 6 seconds until the ipod goes off and the Apple logo appears. After that, it should work like new. Hope this helps.
