Here are the fault codes for your tv and what components are affected:
0 times, Diagnosis: Power does not turn on.
Possible causes include: Power cord is not plugged in, Fuse is burned
out (F6001) (G board). Symptoms of the problem: Power does not come on,
No power is supplied to the unit, AC power supply is faulty.
times, Diagnosis: B overcurrent (OCP). Possible causes: H.
OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D
board) Symptoms of the problem: Power does not come on, Load on power
line is shorted.
3 times, Diagnosis: +B
overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is
faulty (G board). Symptoms of the problem: TV has entered standby mode.
times, Diagnosis: Vertical deflection stopped. Possible
causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)
Symptoms of the problem: TV has entered standby state after horizontal
raster, Vertical deflection pulse is stopped, Power line is shorted or
power supply is stopped.
5 times, Diagnosis:
White balance failure (Not balanced) Possible causes: Video out
(IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is
faulty (A board), G2 is improperly adjusted. Symptoms of the problem:
No raster is generated, CRT cathode current detection reference pulse
output is small.
6 times, Diagnosis: LOW B
OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is
overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms
of the problem: No picture.
7 times, Diagnosis:
Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted.
(D board)
8 times, Diagnosis: High voltage
error. Possible cause: T8005 is faulty. (D board)
9
times, Diagnosis: Audio error. Possible causes: +- 19V line is
shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is
opened. (A board). Symptoms of the problem: No sound
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
There will be a section of the body that unscrews. From the photo it looks like that might be the narrowest section of the torch. Firmly grip the wide head end of the torch with one hand and the body with the other. Gently but Firmly twist them in opposite directions. Turn them the same way a nut and bolt would Unscrew. The head end should separate at the thin section between the head and the handle. I think that torch take 1 AA battery.
This torch has a Proprietary rechargeable nickel-metal hydride batteries (2,200 mAh), that is its made for this torch and nothing else. NiMH like to be kept fully charged and if you discharge the battery too much or leave it discharged it wont charge up fully or at all.
All I can sugest is to trickle charge for 12 hours then discharge fully and recharge for 12 hours again, repeat cycle till it lasts longer or replace the battery.
A replacement battery will be expensive.
I use LED torches with cree led and 18650 Li cells, last much longer than NiMH, easy to replace and cheap.
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Best to turn off oven power at circuit breaker. Grab a strong torch and a wire coat hanger. Straighten the coat hanger and make a small hook on one end. Using the torch light guide the coat hanger loop towards some part of the wire and slowly fish it out.
Hope this helps. Otherwise you will be left with no alternative but to pull oven out (heavy) to access the side cover and remove it. It would be helpful to know the make and model of the oven if you needed more help with getting to the wire itself.
Hello and Welcome to FixYa! A very hot issue being discussed, Sad but true, this isn't possible, all because of Xenon flash, it can't be kept on for a longer time because it my burn itself, and also drains much battery power. The old school LED lights like in K750 were capable of being used as torch, but unfortunately this can't. I hope you will have a clearer picture now.
Concerned, Nooh.
