SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
SOURCE: The carpet brush on my
Next to the power switch is another button, this switches the brushbar on and off. The brushbar can be turned off for hard floor surfaces so as not to scratch them
SOURCE: Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email [email protected]. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
