SOURCE: living solutions giant remote control 3-in-1, A17G0510 (Item606426)
I had trouble programing the living solutions giant remote - c17g0801.
But after many times serching I ran across a genius' resolution (maybe it was 2 genius') -
Jumbo Remote:
Make sure you have device turned on.
Hold the device button you want to program for 3 seconds & release.
Push & release the power button & the red light will remain lit.
Push the CHANNEL UP button over & over slowly until the device turns off.
When device turns off press OK button.
SOURCE: i need a code for a living solutions giant remote
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
SOURCE: living solution giant remote codes for Tosiba TV
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
SOURCE: Need remote code
Programming a Living Solutions Universal
Remote
