Computers & Internet Logo
J
James Anderson Posted on Apr 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony cyber shot 4.1 D.SC. -P43 did not turn on I put batteries and everything
All it did was turn on a green light left of the power button the monitor was black and the zoom did not extend
Stan Naramore
Level 3:
Guru:
  • Sony Master 531 Answers
  • Posted on Apr 30, 2019
Stan Naramore
Sony Master
Level 3:
Guru:
Answers
531
Questions
Helped
208805
Points
2468
Very often with a camera that old with battery types that it uses there is a problem the contacts that must touch the battery when it is inserted.
I use WD40 Contact Cleaner and have had good results, simply rubbing both the contacts in the camera and also the contacts on the battery.
I am certain you have checked that the batteries are indeed fully charged.
I am also guessing you have made certain the battery is installed correctly...many Sony cameras can have a battery installed "Upside-down".
And I am curious if you have tried the USB charger.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jul 08, 2008
SOURCE: Monitor goes blank less than a second after turning on.
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Anonymous
  • 74 Answers
  • Posted on Aug 12, 2008
SOURCE: Sony Cyber -Shot
try gently pulling and twisting the end of the lense and i mean gentle dont pull till it pops than switch it off and on again and you problem should be solved
Anonymous
  • 11 Answers
  • Posted on Jan 31, 2009
SOURCE: monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on May 28, 2009
SOURCE: sony cyber-shot 7.2/display screen is black and
CCD Failure!
known problem contact sony for free repairs dont worry just call them they will do it even if u are out of warranty
see this for sample advisory and problem detail
http://esupport.sony.com/US/perl/news-item.pl?news_id=161&mdl=DSCT1
AMJAD HUSSAIN
  • 586 Answers
  • Posted on Jun 14, 2009
SOURCE: SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
What kind of memory stick is suitiable for my 4.1 mp sony cybershot DSC-P43
it uses a memory stick pro duo that is made by sony
Hope this solution was helpful? Please comment for more information and thank you for using the fixya website.
My Sony Cyber-shot DSC-S600 stopped working. I press the power button and nothing happens. I tried changing batteries, but it shows no sign of life. It was left in the trunk of my car overnight, inside a...
Remove the batteries and SD card, leave the battery door open, and put the camera in a jar along with a dessicant bag or a small bag of uncooked rice that has been opened. Put the lid on the jar and let it sit for a day or so. This should absorb any condensation inside the camera that may be keeping it from working properly.
Sony cyber shot dsc-s500 is not turning on..
I'm not sure if this will help but you might want to try removing the memory card and powering it back up. If the camera stays on than there is probably something wrong with the card. Try a new card and see if that helps.
2answers
Camera won't turn on
There was a POWER button.Please press the button.The button will show GREEN.
1helpful
Flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Hope it will solve your problem....
3answers
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
Power on
Hi
You need to open up the camera again and check all the connections for the cables and make sure everything is connected properly. Most likely it's just a cable that isn't plugged in properly.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
It will not turn on
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
2answers
Wont turn on.... flashes on then off
Get out the batteries then leave the camera for about one day, Put a pair of new batteries then try to switch on.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
