Question about LG Refrigerators
My LG fridge is making noise when doors are opened. It is a Double door fridge with bottom freezer
    Top Expert:
  • LG Master
  • 10,402 Answers
Temp sensor alarm fridge too warm
Posted on Apr 30, 2019
6ya staff
SOURCE:
DrLindquist
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
Anonymous
SOURCE: LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Posted on Sep 22, 2008
Michael Anderson
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
Anonymous
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
paulo1975
SOURCE: my LG refrigerator model #
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
Posted on Sep 25, 2010
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
My fridge is really quite and today i came home and it sounds like a motor is humming or grinding!! when i open the fridge doors the noise goes away?
if there is no problem in the functioning of this fridge then the noise isn't a problem. but still i would advise you to have this fridge checked out by your local repairman.
Jun 11, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Mar 04, 2009 | Refrigerators
Sep 10, 2008 | Refrigerators
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
