Every thing else including ARC works perfectly. Set up is: cable box, Samsung 4K Tv, Sony BlueRay, AppleTV, Yamaha RX-V485.
Hello Claude, for what you describe, in your YamaHa when you select the input to listen to the TV, you see DVD, you can change the denomination of the entries
I sent you the link, so you can download the user manual, there, on page 79, you will find the way to change the name, as you wish
I hope you succeed in resolving the issue raised
Greetings Franco Dosil
Hola Claude, por lo que describes, en tu YamaHa cuando selecionas la entrada para escuchar el TV, te aparece DVD, puedes cambiar la denominacion de las entradas
Te envio el link, para que puedas descargar el manual de usuario, ahi, en la pagina 79, encotraras la forma de como cambiar el nombre, como tu deseas
Espero que logres resolver el tema planteado
Saludos Franco Dosil
https://mx.yamaha.com/files/download/other_assets/1/1161671/web_AV17-0136_RX-V585_om_UCRABGLEFPH_En_B0.pdf
SOURCE: JVC RX-888V hook up to cable box - no video
There is some sort of setting you need to change on the JVC receiver. I had this same problem, and I read the manual and it solved it. You need to press and hold down a button to change the mode. Your unit probably says "TV Sound" right now. Once you press this button (not sure what button) like the manual says, the display should change to "DBS" and then it should work just fne.
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
