Will not feed wire when trigger is pulled to weld. The welder is set up with a gas valve for inert gas shielding. That solenoid does operate and the weld current is present when the trigger is pulled. Presently I am going to use flux core wire. I have no gas tank connected. Also the feed does work in the ''inch'' mode when loading new wire.
I looked for a pressure switch thinking there has to be gas pressure present for the feed motor to operate. Didn't find one.
I don't have a schematic for the welder. I was told this unit is from the '80s.
What kind is it?
