SOURCE: Only wants to print out of tray 1
go to menu
in the configure device
printing
select override A4/ Letter to yes
then it print automatically from tray2 & 3
kindly ensure if u r using A4 sheet that setting is not in tray 1 paper size
SOURCE: Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
SOURCE: hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
SOURCE: Printer always prints from bypass tray...
Check the setting in / on your computer. Make sure it is not set to default to the bypass tray.
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
