The bulb works with the lights on but the turn signal doesn't work - right front works okay - wondering what else to check - fuse possibly?
Remove the bulb. Verify that both filaments are good, or replace the bulb. Also check or clean the bulb socket contacts. Use a test light or Volt/Ohm meter to verify the correct voltage is at both contacts in the bulb socket. If a voyage is missing trace back through the wiring to find out why the voltage is missing.
SOURCE: brake lights/rear turn signals
I had the same problem with my 1999 Yukon. The electric board needed to be replaced. Rust starts to build up and shorts out or blows the bulb. The dealership charged $73.60 for the part and I installed it myself (Saved $30).
SOURCE: rear brake lights don't work
you prob got a trailer plug prob bad wires if not tail lights run through turn signal switch tell fix ya bout me ok
SOURCE: Brake light, Turn signal not working rear right 06' Focus
I have a 2000 ford focus no brake lights. with the brake lights the transmission would not go into drive .replaced the brake light switch checked fuse replaced turn signal switch with no results then i moved onto the wiper switch and replaced it as much to my supp rise it fixed the problems
SOURCE: rear left and right turn signal lights not working.
the electronic flasher module may be faulty, or you could have blown a fuse
SOURCE: 99 Chevy Tahoe... Rear turn signals, brake lights, and hazards
I had this problem, and to be honest, it happened to the left side about a week later...it's the board that the bulbs plug into...it's a very common problem with this model. So popular that you can normally get the socket board off the shelf at a parts store! it's extremely simple to replace, and I replaced all the bulbs at the same time!
