Thanks Ernest!! You sound like the professional they are looking for!!! Is your fan in the auto position at the tstat.
Testimonial: "Replaced sequencer and limit switch, problem solved."
There are several things that can cause this symptom. Professional training and tools, experience are needed to fix it, and probably some parts. If you had the tools, training, and experience you would not be posting on this forum. Call a professional. It will save you time and money in the long run.
SOURCE: i have a nordyne E2EB-012HA.
Unhook the thermostat wires at the unit... if it stops then the wire or the t-stat is bad...
if it still runs then the contactor in the unit is bad...
heatman101
SOURCE: need pictorial wiring diagram for
kindly get here the service manual with diagrams for you e2 model. hope that helps and thanks for using fixya.
