Stainless steel door with handle came off on Frigidaire over the range microwave. The glass plate assembly is still in tact
SOURCE: Inner 'glass' of door
The inner glass can and should be replaced. It protects the metal mesh screen from getting dirty, which can cause it to be damaged and allow microwave leakage. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened. Look for this first and let me know if there are no set screws. If this is your setup then I would appreciate a solved rating.
SOURCE: Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
SOURCE: GE Monogram ZMC1095 Built-in Microwave.
You can find the exploded view on the searspartsdirect.com website. You need to enter the complete part number, or ZMC1095BB001, and confirm colors befor eordering parts.
SOURCE: Kenmore gas range model 790 door glass shattered, handle problem
We have suffered the same problem for the past 3 yrs. We first had the door all fall apart and I screwed it back together thinking that someone missed tightening a screw. Then shortly after the 1 yr warranty was up it happened again. Sears would not help, first told me that there was a recall, then not. After 6 departments and 12 people later they sent me on to whirl pool the manufacturer who said "see sears".
Anyways since we are abandoned by Sears who we trusted (as parents did) we are on our own, here is how I solved it.
After several times of the screw popping out and chipping and stripping the treads in the handle; I too switched out the bottom handle with the top but now at 3yrs old both handles had the threads stripped and chipped and the oven door fell apart during Thanksgiving dinner with the mother law 2009.
The next step for me after another round with Sears with no results (except they said it was common problem) and a letters to Att. Gen. (keep the letters flowing as they are hearing) was to go to the hardware store. I was able to find (not at the main hardware stores, had to go to mom/pa old fashion hardware store) a packet of #10 Sheet metal screws (Stainless steel) 2 1/2" long and a flat washer. This worked. Cost $1.18. Note it does strip the factory threads, so if your present threads are not too bad you may not want do it. You need the washer because the 2 1/2" is slightly too long. 2 1/4" would be a better length but I could not find them.
I would think Sears would want to avoid the bad press by sending all of us $1.18 worth of hardware out. Sears offered to sell me new handles, but I was not about to give them any more of my $.
And I agree it is a very stupid design to have to small handle (where the most stress is) holding the door/glass together.
Note if glass breaks, do not mess around, buy the proper part to go back in.
