SOURCE: Brother mfc8460n wireless printer going offline.
I had the same problem and call customer service (877-276-8437). Customer service will walk you through the process. You will have to configure you I.P. address along with other steps.
One thing I can tell you is to make sure under the Menu option...Network....WLAN...TCP/IP...BOOT Method....make sure it states STATIC.
SOURCE: brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
SOURCE: Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
SOURCE: I have brother Printer HL
hello
printer becomes offline if it is turn off or the pc not recognized the printer.
solution: check the cable printer, transfer cable printer port to another port in your computer, if the problem still occurs re-install the printer driver.
thank you
