SOURCE: My AEG oven is switching off by it self after about ten minutes.
think it shutting of as its getting to hot
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
SOURCE: Oven is AEG Competence, single oven, fan assisted,
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
