Amazon:
https://www.amazon.com/Remote-Control-Replacement-Samsung-AA59-00666A/dp/B07P7YW38D/ref=asc_df_B07P7YW38D/?tag=hyprod-20&linkCode=df0&hvadid=242074892521&hvpos=1o1&hvnetw=g&hvrand=6323188245973282307&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1014106&hvtargid=pla-663388074654&psc=1
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
SOURCE: remote tv control
http://www.scribd.com/doc/2304654/Samsung-HPS4253-Manual
page 43 and 47
cheers
Richard
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
SOURCE: Samsung TV model CT 5029V - Lost remote control - AIR/CATV
do you have a menu button on the t.v. itself? if so gain access there
remote
control codes:http://www.xdiv.com/remotes/
http://www.remotecodelist.com/remotes/rca/rca.htm
