read the instruction manual,
Geneva Watches with Two or Three Hands
Pull the crown out until you feel a click.
Turn the crown counterclockwise until you have the correct time.
Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
Pull the crown out until you feel two clicks. This second click position allows you to set the time.
Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
Pull the crown out until you feel one click. This first click position allows you to set the date.
Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
Pull the crown out until you feel two clicks. This second click position allows you to set the day.
Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
Pull the crown out until you feel a second click to set the time or the 24-hour hand.
Turn the crown clockwise until you have the correct time, then push the crown in to set it.
Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
Pull the crown out two clicks. This second click position allows you to set the time.
Stop and start the chronograph by pressing the PA button, located above the crown.
Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
Wind the mainspring by turning the crown 15 to 20 times clockwise.
Pull the crown out until it clicks.
Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
keep pushing buttons till something changes.Usually you hold a button down for 3 secs then things start flashing,then you forward it to the time section
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
