1 ANSWER I GOT WAS A BAD AV CORD,CANT BE THAT IF IT WAS THE DVD PLAYER WOULD NOT HAVE A PICTURE AND SOUND,ONLY THE VCR HAS NO PIC OR SOUND,WHEN SWITCHING FROM DVD TO VCR PIC FLASHES ON SCREEN FOR A SEC AND GOS AWAY,DVD SIDE STILL FINE
SOURCE: LG V8824w DVD/VCR no video
rtfm.
Once the setting for progressive scan output is entered,
an image will only be visible on a progressive scan
compatible TV or monitor. If you set Progressive Scan
to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc
tray. See that "NO DISC" is displayed on the display
window.
2) Press STOP and hold it for five seconds before
releasing it. The video output will be restored to the
standard setting and a picture will once again be visi-
ble on a conventional analog TV or monitor.
SOURCE: My Toshiba SD-3960 sound does not work.
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
SOURCE: Dvd player-No pic yes sound
Try using the I/P button on the remote. Toggle between S-video, RCA and composite video outputs.
SOURCE: DVD tray in SD-V296 will not open
Hi!
Thank you. Yes, we did solve the problem; in fact, it was the way we had solved it one other time, even though I had believed it a fluke then:
we simply disconnected the unit for a couple of hours, plugged it back in and, just as last time, the tray opened easily.
Sincerely,
Dean Hunt
SOURCE: Won't play DVDs.
My problem is just the opposite; the DVD player is fine, but the VCR starts and then powers off the machine.
