Unfortunatly the impact from a fall can lead to numerous problems ranging from a broken fuse to a disloged power supply to a cracked board. I'd suggest taking it into your nearest Roland authourized service center to get it checked out. If you're not trained in electronics you can do more harm than good poking around inside the amp. https://www.roland.com/us/support/service_repair/service_centers
SOURCE: Roland micro cube dosnt power up
Check the fuses. There is probably one on the outside of the amp and some inside the circuit board.
