Hello, the Android Operating System is as complicated as any other, it has its advantages and its disadvantages, but it is definitely good, I send you a video that has several alternatives to solve that problem and I hope so.
By the way, if you want to change the ROM you must choose an appropriate one that doesn't have complications, I can also leave a link, but if you are not sure or do not know how to do it ... don't do it.
https://www.xda-developers.com/how-to-install-custom-rom-android
SOURCE: HUAWEI U511 Launcher has stopped.
boot into recovery and factory reset... or flash a new one. this isnt your exact model but it may work http://kyawzayarmin.blogspot.com/2013/09/y511-cwm-recovery.html
SOURCE: I have a crystalview xt android tablet or PC and my system UI stopped working
• You need to switch off your tablet
• Then press/hold power+volDOWN+home just keep pressing it
• Then it will switch on with a word start in it let go of the buttons you are holding
• You need to click on the VolDown twice so a recovery mode will appear.
• You need to click power so it will restart to recovery mode
• An android image will appear that has a red exclamation mark
• After which you need to hold down power and then press VolUP
• You need to use volume to scroll and press power to select "wipe data/factory reset"
• Then you need to scroll down again and press power to select "yes-erase all user data" This will now start your tablet to reboot Then it will switch off then switch on again.
