I assume you are referring to the Hangrohe.
https://images.homedepot-static.com/catalog/pdfimages/a7/a79e5618-65fc-4e21-9a59-dd8bcc4773aa.pdf
It appears there are detents that hold the handle so push ON and pull OFF. Firm grip and pull should remove the handle. Although, if yours has leaked for weeks/months, corrosion/deposits under handle may make it difficult. If coldle hand doesn't budge, try removing the hot as it has not been leaking and may pop off with less effort. Then go after the other. Note; you may as well replace both cartridges.
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
SOURCE: The faucet handle has become stiff to turn off and
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
SOURCE: I cannot get the set screw out of a Delta
You can't apply any worthwhile heat to try and free this off without causing further damage, but if you have a pipe freezing kit handy you can try freezing it a few times and then pouring boiling water over it to thaw it suddenly. The thermal shock sometimes works but it's not a sure enough thing to be worth specially buying a freezing kit for.
That leaves two other possibilities: drill the screw out and get a replacement (or adapt one from another machine screw) or partially drill it and use a very small stud extractor. If the screw is brass then just drill it out in my experience as stud extractors just don't work on small diameter non ferrous materials.
If you drill the screw out then you need to use a drill bit small enough to go down the centre of the screw without damaging the threads, but large enough to leave it sufficiently thin-walled to be able to collapse inwards when you subsequently winkle it out. Usually I find that a pin punch driven anticlockwise against the thin rim left after drilling does the job.
