Oil tank was filled and the lockout started. Thanks Rich
SOURCE: r7184b just got oil reset wont reset tried main
if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
SOURCE: Lockout light flashing for 1/2 sec.
Press down and hold the reset button. You may need to bleed the oil line once you get oil in the tank.
SOURCE: Honeywell Beckett Oil burner locked out.....just
how do you reset a beckett oil burner when your locked out ?
