Computers & Internet Logo
John Marks Posted on Apr 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm running OS 10.13.6 on a mac book pro. My Iomega MDHD500-TE is not recognized. What to do?
Don A
Level 3:
  • Iomega Master 4,495 Answers
  • Posted on Apr 17, 2019
Don A
Iomega Master
Level 3:
Answers
4495
Questions
5
Helped
1336122
Points
25824
I suspect that you don't have an Iomega driver in play for use with this Macbook pro that the OS recognizes. There are other possible explanations, you might have a corrupted volume or there might be a problem with the file structure on the Iomega. But if the Iomega was not previously recognized by this MacPro, I think what is missing is a useful driver. You might try one of the driver hunter utilities and see if it finds such for the iomega. If several are found, you would have to try each one at a time and uninstall any that did not work before trying the next, I think.
Here is something else you might try. On the MacPro, on the desktop go into Applications>Utility folder and from the Utilities folder launch the Disk Utility application. If your Iomega is discoverable, it will show up in the left side of the Utility window. If you see it, click on the left side of the window and choose Disk Repair.
If you don't see it in the left side of the Utility window, you may have a corrupted volume preventing it from properly being read on your Mac or there may be a problem with the file structure of the Iomega.
5 Related Answers
Lucky
  • 271 Answers
  • Posted on May 14, 2008
SOURCE: external drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
Anonymous
  • Posted on Mar 08, 2009
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
Anonymous
  • 1305 Answers
  • Posted on Sep 15, 2009
SOURCE: I have a Iomega MDHD500-UE that has worked fine
I would very soon, purchase a hard drive and get all the files off this drive asap.
I had a drive that would work with symptoms like this and it eventually completely stopped. I heeded it's warnings and got all my file off and backed up onto another drive before it was too late. Plus drives ...big sized are really inexpensive right now...
Get a backup.... don't take a chance..
Anonymous
  • 14 Answers
  • Posted on Aug 20, 2011
SOURCE: i have the lexmark X75..but my computer is a apple
If your problem is that you can't print try downloading this driver click here
Anonymous
  • Posted on Dec 15, 2012
SOURCE: lockbox export/import connectivity problems
Use the IP address of your iphone (check Settings/Wifi/network details) and add :88 to this address.
2answers
I want to use in my mac osx mac book pro
Hi Carmen; just plug it in to your system's USB port and format it for use with a mac os according to the provided instructions.
According to the manufacturer: Mac:
  • Built-in USB
  • Mac OS X 10.4 - 10.6
  • 128MB RAM
  • Drive must be reformatted for use with Mac (instructions included)
Broken mac book pro screen
Check your user manual for a start. These models the early 2011 models of MacBook Pros work in TDM. See OS X Lion: Use another Mac as a display.
1helpful
3answers
I have an Iomega MDHD500-N external hardrive. I erased a folder of photos accidentaly. How can I recover the photos?
Did you look in your recycle bin. If you are lucky you may be able to restore them from there. Other than that, that is why they also say to do a backup every once in a while. Please rate my answer to I am rewarded points for it.
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Describe your external hard drive iomega MDHD500 Problem: I've just bought a MAC OSX computer which doesn't recognise my iomega hard drive (used on a PC) is there a way to fix this?
Are there any files on the disk-drive that you want to keep?
If so, connect it to a PC, and copy those files.
If not, connect it to the Mac, and allow the Mac to 'format' the drive, to initialize it for use on the Mac.
Got new macbook pro. Iomega external drive is not recognized on desktop
Have you used this drive on a mac before?
Windows usually uses a different file system to macs. You may need to format the drive to work with macs.
Sorry if this was not your problem, you may be better off looking on mac forums.
Good luck
I have a Iomega MDHD500-UE that has worked fine for probably 18 months but in the last week my Apple NoteBook Pro is losing connection with it after about 5 to 10 minutes. I upgraded to Snow Leopold about...
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
