Hello Waseem, check that you have the connections between the Pioneer and your TV, so connect from the Pioneer's HDMI output to the HDMI input on the TV, with an HDMI-HDMI cable
Verify that the TV is selected for the Blu-Ray input
I hope you have luck in the checkup
Greeting Franco Dosil
Hola Waseem, verifica que tengas bien las conexiones entre el Pioneer y tu televisor, osea conectar desde la salida HDMI del Pioneer a la una entrada HDMI en el televisor, con un cable HDMI-HDMI
Verifica que el televisor se encuentre seleccionado para la entrada del Blu-Ray
Espero que tengas suerte en el chequeo
Saludo Franco Dosil
SOURCE: DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
SOURCE: I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
SOURCE: Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
SOURCE: need to reset my dvd player
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
