SOURCE: The pull cord on my
On mine, the screw was bigger than the hole at the end, so there was no way to get it out. I used a hacksaw and sawed lenthwise down the shaft (the clutch housing) on the edge so I could see where the drive shaft was (you don't want to cut this). Then I cut accross the shaft (clutch housing) to expose the inside. Now I use a common screw driver and take the screw out. It also take a tourqe (star) wrench like the other screws. I guess if I don't replace the clutch I'll use it for a RC boat or something...
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
SOURCE: Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
SOURCE: New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
SOURCE: trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
