SOURCE: Unable to program Universal Remote. provided codes do not work.
Problem solved. I decided to use the learning function of my remote to learn the wanted commands of the original remote. The remote I used was a Sony RM-VL610 which could learn the original remotes functions easy and quickly. This is a very good remote for only $30 purchased at Target. The Macro commands were also entered rather easily. I did not try this method originally,because I thought it would be too time consuming and difficult.
pcwg
SOURCE: Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
SOURCE: Sharp Blu-Ray model BD-HP20X locked to region 4 how to unlock ?
Well I Checked my data resources and saw that there are no hacks or tricks for Sharp yet... the only thing you can try doing now is to ask your Dealership if they can unlock the regions for you. I've searched everywhere but couldn't find anything for newer models like HDDVD or Blu-Ray players.
Sorry T_T But let's hope someone might be able to help as well..
SOURCE: Unlocking of Samsung BD-P1500
I have a new BD-P1500, and after 5 Times
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running
090417_01_BDP1500_XAX.RUF
I used the R4 code from below.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
Now it to me about 5 tries to get this to work, It needed to be done without delay.
So if you don’t get it to work straight away don’t loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Report this hack (requests/questions/spam/wrong/****).-->
Region code hack posted by wasgo, September 17 2008:
I have tried the hack mentioned above on my new BD-1500 and couldn't make it work. But the software in it is about a month newer.
Does anybody have any new ideas how to solve the problem?
I have the region 2 version (Sweden)
