3351734A TIMER SWITCH WIRING
SOURCE: timer and door switch for bosch washing machine V428
www.spares2go.co.uk/browse-BOSCH-Spares-m113.htm
www.spares2go.co.uk/browse-BOSCH-Washing_Machine-spares-m113-t713.htm
www.espares.co.uk/search/washing-machines/p/1085
There you go.
SOURCE: removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Hi Clint Mathis, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
