Maytag MER6775A Electric Kitchen Range Logo
Ken Hearnsberger Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lower element of top oven does not heat on Maytag Gemini
The lower element of the top oven of my Maytag Gemini (model MER6772BAB) will not heat on either baking or cleaning cycles. I have just replaced the element but the problem persists. The top element functions just fine.
Anonymous
Level 3:
  • Master 998 Answers
  • Posted on Aug 06, 2009
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
248345
Points
3069
Replace the control
Lower element does not heat
most likely the element needs replacing, check for arcing holes,melted spots. check fuses, normaly under cover at top of stove. element is easy to replace(a few screws), unplug stove when doing so.
Lower bake element in lower oven does not heat. What are common problems & can I get a fault code to display if I do not have one on the display, or does it mean none are present if not displayed? This...
Remove the lower bake element and test the ohms. If none replace the oven element and its fixed. The element is usually the problem and its fairly cheap to fix.
Maytag Gemini top oven, the bottom element does not get hot. I replaced the element with a new one from maytag. what is the problem?
Hello jrlibs
Welcome,
You said, Your Maytag Gemini top oven, the bottom element does not get hot. You replaced the element with a new one from Maytag. Asking what is the problem?
1.What is the model number and the year of your Gemini Range?
2.Was there an error code that came up before you changed the heat element?
3.If yes what was the code?
4.Did you check for current in the connection leading to the element before you installed the new one? Or just plug it in hoping for the best?
Waiting for your reply!
Huuum
MER6779BAW Range/Double Oven
I haven't checked anything but the heating element. The fault codes read F0-0, which means no fault but..... ?
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
