That 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
the true sticker is on the bottom of this mobo. that is current,
the number you used is useless for support.
n1996
in fact the MSI forum posts repeat that over hand over, at MSI.com
go there and read, or post what to do.
or read the manual there, all you need is in the free manual, how to set up this mobo.
MSI is top brand. like Asus.
SOURCE: Connection Diagram for MSI N1996 motherboard
GOTO MANICATURE WEB SITE TECHN SUPPORT MOTHERBOARD LAYOUT DIAGRAMS
TRY MOTHERBOARD.ORG
IM PRETTY SURE THAT MSI DOES HAVE A WEB SITE ON THE INTERNET
CANDYMANGANDY
SOURCE: i need msi drivers for an n1996 motherboard
Hello I have provided a direct link to the drivers for your motherboard. The drivers are free to download. Hope this helps.
Click on link below:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Please rate my solution. Thanks
SOURCE: I need a manual for an acer N1996 motherboard (I
It's a KM4-AM-V MSI motherboard.
Manual on http://global.msi.eu/index.php?func=searchresult&keywords=7061
