Hello, i have a kia spectra 2.0 year 2004 and the air conditioning is blowing hot air and i have found out it is due to the fact that AC compressor i blealive lost power. How much would it be to fix it and what needs to be fixed?
In almost every case, it is most likely low on freon. Most all systems use some type of pressure switch to prevent the unit from freezing up via a low pressure switch. It also acts as a "Loss of Charge" safety. I would think there is a leak. Most of the time it is in the condenser, evap, or compressor. Usually not real cheap to fix but you got to check it out to be sure.
