Hi Paula, there is the cold reset procedure, the cold reset clears all the data, including the predefined data stored in the RAM to the initial conditions
Process:
1) Press the Power button and turn on the computer,
2) Press the power button, the Stop button and the eject button, simultaneously
3) When these three buttons are pressed, the display will show the COLD RESET indication for a while and all the settings are reset
I hope you have served the information
Greetings Franco Dosil
Hola Paula, existe el procedimiento restablecimiento en fr?o, el restablecimiento en fr?o borra todos los datos, incluidos los datos predefinidos almacenados en la RAM a las condiciones iniciales
Procedimiento:
1) Presiona el bot?n de Encendido y encienda el equipo,
2) presione el bot?n de encendido, el bot?n de Stop y el bot?n de expulsi?n, simult?neamente
3) Cuando estos tres botones est?n presionados, en la pantalla aparecer? la indicaci?n RESET FR?O por un tiempo y se restablecen todos los ajustes
Espero que te haya servido la informaci?n
Saludos Franco Dosil
SOURCE: What is the master reset code for Sony Ericsson P990i
master resetcode for sonyericson P990i
SOURCE: hook up Sony Bravia Home Theater DAV-HDX277WC
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
SOURCE: Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
SOURCE: What is the default system manager password for a
Have you tried to just leave it blank? Most Canon copiers you can just leave it blank.
