I have lost it in a move and need to replace it but do not know what part number to order
SOURCE: Need USB Cable for JAZZ JDC27
You can get that cable at your local electronics store, or you can get it online. I believe it is a USB mini b.
Thanks for coming to FixYa.
Rob
SOURCE: Need User Manual
Hope these links help you out.
Here is a link to a generic manual for the HDV-188.
Here is another link to a discussion forum, there are a few more links on this page you might find helpful.
Thanks, and please rate my solution if it is helpful to you.
SOURCE: I lost the cable to charge my Jazz HDV178 digital
Hello there:
If you contact the manufacture of the device they probably will be able to help you locate the cord.
Also radioshack or best buy or a reputable electronics dealer should also be able to help you get what you need. ok?
hope this helps you out some..
best regards mike
SOURCE: Battry charger
i lost my charger for my jazz hdv 178 camera and i dont know how much another one will cost,do you know how much they cost and where i can probably get one.
SOURCE: how long should it take to format a 8GB sd card in a Jazz camcorder
okay I had the same problem. Turns out you really have to push the SD card in pretty hard. It should be flush with the base (as in not sticking out at all). Did that worked like a charm.
